What about ones that are for ios 7? I don't install anything unless I know it's updated. Just curious to see what can be causing my slight drain. could just be the type and amount of tweaks I have
If you have any kind of widget that updates like weather, change the interval to something farther apart like 30 minutes or every hour. That can cause a drain. Some of the ones I've got by default are 10 minutes or less.
