Anyone experiencing drastic battery drain on iPhone 5s after Jailbreak?
- I had my iPhone 5s since November and i haven't complained on my battery life at all until i jailbroke it and ever since it has been draining the battery like crazy even if i'm not using it! This morning woke up at 100% charged over night at 7:00 AM and at 12:30 PM my battery was 28%/. I don't think this is normal and i also don't know if it's the jailbreak that's causing this or not. I was thinking that f.lux and Bytafont 2 might be the reason of the battery drain so i deleted them and i am still testing it now. Please tell me if you're experiencing the same thing and what did you do!01-16-2014 12:07 PMLike 0
I literally did the same thing man, I feel your pain and I feel for you! I obsesses about my battery so much I eventually used a status bar tweak to remove my battery completely so I wouldn't worry about it so much!!!
If you research threads started by me you will find my battery drain thread.
It's probably all in your head!fb2 likes this.01-16-2014 06:46 PMLike 1 -
Sent from my iPhone using Tapatalk01-16-2014 10:04 PMLike 3 -
Sent from my iPhone using Tapatalk01-16-2014 11:16 PMLike 0 - Unfortunately when you resorting it wipes the stats. Haven't found a battery stat tweak yet, really haven't looked for one. But here's my installed tweaks. http://img.tapatalk.com/d/14/01/17/ve7y3ujy.jpg http://img.tapatalk.com/d/14/01/17/2ubymu5e.jpg http://img.tapatalk.com/d/14/01/17/y9egameq.jpg http://img.tapatalk.com/d/14/01/17/8e4u5yhu.jpg http://img.tapatalk.com/d/14/01/17/egada5y7.jpg http://img.tapatalk.com/d/14/01/17/qesaqyge.jpg
Sent from my iPhone using Tapatalk01-16-2014 11:25 PMLike 0 -
Sent from my iPhone using Tapatalk01-16-2014 11:29 PMLike 0 - That's great! I enjoy being jailbroken and I have yet to experience a drain either. This is my third iPhone and I hope we both continue to be lucky.MikeG7265 and RobertAdams313 like this.01-16-2014 11:32 PMLike 2
Sent from my iPhone using Tapatalk01-16-2014 11:32 PMLike 0 -
- I am using iphone 5c and experiencing same issue since last week. everything was fine though my phone was jailbroken. at first i thought that my settings was draining my battery much faster so i turned push notification for mail off, backgroung refresh off, bluetooth and location off, data and 3g off,moreover all off. then for testing i charged my phone to 100% last light around 12 am. i closed all my background apps and kept it in an airplane mode just to make sure whether that helps. but i got shocked this morning at 7 am to see that my battery level was 68%. i have no idea what else to try. i am running ios 7.0.6. so does upgrading to 7.1 solves this? but i don't want to updated my phone until and unless that is the only option i have.04-20-2014 09:47 PMLike 0
- I Restored It By DFU Mode State After Done My iPhone 5S Was Fully Charge And At Least 84% Of My Battery But I Lose The Jailbreak When I Restored It So Pls Answer This Question What's Happening To My iPhone?05-10-2014 04:34 AMLike 0
- To test the battery itself for drainage problems, do this test. If the battery is ok, then there's something somewhere draining it. It could be a tweak, an app or extra usage. There's some who start using their phone more then complain about battery %. Some people need to turn that battery % in the status bar off. They obsess with it. Here's the battery test:
Your Usage time should be accurate to how much you've used it since you took it off the charger.
So here's the test: write down your Usage and Standby time, press the sleep/wake button (or lock button, as some call it) to put the device to sleep, and set the device down for five minutes. When you come back, take note of the change in time. If your device is sleeping properly, then the Standby time should have increased by five minutes and your Usage time by <1 minute . If your Usage time rises by more than one minute, you have a drain problem. Something is keeping your device from sleeping properly, significantly shortening the time it will last.
Sent from from my iPhone 5fb2 likes this.05-10-2014 06:55 AMLike 1 - Every month there are some people who say that they have drastic battery drainage and they don't know why, I didn't check it but I think it's the most asked question why this happens and what to do. And it gets answered every time, but those people are to lazy to search for it...
-- enough hating--
I answered a similar questions some time ago, I quote myself here:
Comment:
- To be honest... I really don't know why you have all the stuff on your device. Of course they're cool and some handy, but I would recommend you to use a app like Springtomize which gives you the ability to configure most of your device and IntelliScreenX, which is already installed on your device. Springtomize make a lot of your tweaks redundant, like NoPageDots, NoNewsIsGoodNews, InfiniFolder, HomescreenDesigner and lot more
- You can reduce the possibility for incompatibility and crash if you have less number of tweaks (from different developers) on you device.
- Furthermore I wouldn't recommend to use iWidget and HomscreenDesigner, especially together. They're known for incompatibility with some tweaks and also led my device to a lot of crashes. If you still want to modify the Homscreen use Springtomize which give you really awesome features.
- You also have a lot of different tweaks and themes which interacts with the lock screen. That's also not good, you should chose the one which is most important for you and not many together.
- IntelliScreenX is still in beta and also crashes a lot on my phone, that's why I replaced it with LockInfo, which is 1000 times better but also have some issues because it's also a beta.
To summarize:
- Use less apps/tweaks with a lot of features instead of many apps/tweaks with less features
- Remove all tweaks, apps and themes which aren't important or really necessary
- Use Springtomize and therefore remove all tweaks and feature you don't need anymore
- If you don't need the all features of IntelliScreenX and just use it for something like displaying your calendar on the lock screen, then use simpler tweaks like "Calendar for Lockscreen"
I hope that helps you
I checked all your installed stuff and have to ask you:
Do you really need all of the stuff and do you know what the tweaks are doing?
It seems that you "just" installed everything which seemed cool to you.
Just ask yourself which functions are important for you and remove all stuff which is not needed. Furthermore as I quoted; do the 3 following things
I can recommend you to remove some stuff and to replace a lot of your installed tweaks (with reasons):
- Barrel (use Springtomize instead)
- BioProtect (is cool, but do you really need that? I can image that this drains battery)
- Bloard (unnecessary)
- CCDesperator (use Springtomize instead)
- CCClockOpenToAlarm (use CCToggles instead, offers the same and lot more)
- CControls (use CCToggles instead, offers the same and lot more)
- CCHide (use Springtomize instead)
- Cloaky (unnecessary)
- DismissSwitcher (really? don't want to be offended, but that's not necessary)
- DockShift (use Springtomize instead)
- Flat Notes (One of the most fitting comments from iDB to this tweak:"Probably the most useless tweak yet."- remove that)
- HiddenSettings7 (use Springtomize instead)
- Infinidock (do you really need that?!? Use folders or Activator menus instead
- iOS 7 Cydia Icon (remove that)
- Purge (use CCToggles instead, it has also this feature and lot more)
- VoicemailRemover (that's ridiculous, why would you need this, are you starring at the phone app the whole day or why do you want to remove the button? -.-")
- WinterBoard (drains battery a lot, but if you want to use it, then use less themes and not a lot of themes together or "moving" stuff)
- Zeppelin (not recommendable, but if you still want to change the carrier and other stuff of the status bar use Springtomize instead)
Those are just examples, I would also remove most of the other tweaks which I didn't mention which is in your list, but that's not my cup of tea. Customize your device as you like
PS: I see "Repo Icons" for "xSellize" and "SiNfuL iPhone" in your installed list... as far as I know that are repos with pirated/cracked stuff. I highly recommend you to remove the repo and all cracked stuff if you use them. I really hate pirates, so (if you use cracked stuff then) I won't help you anymore, just saying :/05-10-2014 02:10 PMLike 0 - To be honest... I really don't know why you have all the stuff on your device. Of course they're cool and some handy, but I would recommend you to use a app like Springtomize which gives you the ability to configure most of your device and IntelliScreenX, which is already installed on your device. Springtomize make a lot of your tweaks redundant, like NoPageDots, NoNewsIsGoodNews, InfiniFolder, HomescreenDesigner and lot more
That's right, it seems stupid, but just remove the % from your battery and stop looking at and thinking of the percentage the whole day. I know a lot of people who grab their phone almost every minute and check if they "lost" a percentage. Of course you will "loses" battery if you turn on the screen every minute and put it back (especially without pressing the sleep button and with a high auto lock time). If you use your device a lot then you'll also lose some battery, that's normal. If you have more apps, tweaks and processes then the battery will die earlier. There are a lot of stuff you can do to reduce the drain, e.g. removing stuff like locations services, background sync, parallax effects etc.05-10-2014 02:23 PMLike 0 - Not sure which tweaks of yours will be causing battery drain but change your settings in Cydia to developer and download top. If you have mobile terminal then cool if not then download it. In mobile terminal enter in "top -u" without the "". This will show you if there are any processes running rampant on your device. Remember to press q when you're done
Sent from my iPhone using Tapatalk05-16-2014 11:13 AMLike 0 - I experienced drastic battery drain when i started using 3G unrestrictor, zeppelin and haptic pro on 7.0.6 and when Pangu released their JB i updated to 7.1.1 and i'm jailbroken now and the battery performance is slightly better with the same tweaks installed, but when i uninstalled them the battery was perfect
iPhone 5s 32GB using Tapatalk 207-10-2014 02:20 PMLike 0 - yeap... i think i,m facing the same problem with my iphone 5s.. is there any soliution tou found..???07-31-2014 09:05 AMLike 0
- My Iphone 6 is not Jailbroken but the battery on every Iphone I have had seems to be getting worst with every model.
The Phone should last all day with out changing 2-3 times per day.
Apple has a great Phone but a horrible battery. I have to carry a second phone just to stay up on business calls.09-28-2014 11:56 AMLike 0
- Forum
- Apple Software & Systems
- iOS
« [SOLVED] Stuck at 60% with TaiG
I updated my iPhone 5 to ios8.3 now I cannot get signal, how can I fix this? »
Similar Threads
Thinking of Trading my Note 3 for iPhone 5s..
By yungboi in forum iPhone 5sReplies: 91Last Post: 04-16-2014, 06:08 PM -
How to install BiteSMS beta for iOS 7 on your iPhone
By iMore.com in forum iMore.com News Discussion & ContestsReplies: 0Last Post: 01-16-2014, 11:50 AM -
What's really going on with the Starbucks mobile app information leak, and what you need to know
Thinner MacBooks make bigger battery problems
By iMore.com in forum iMore.com News Discussion & ContestsReplies: 0Last Post: 01-16-2014, 11:40 AM -
iMore show 383: Paul Kent on Macworld|iWorld 2014
By iMore.com in forum iMore.com News Discussion & ContestsReplies: 0Last Post: 01-16-2014, 11:20 AM
