Most of us were complaining about battery drain after updating to iOS 7. After a ton of trial and error the past few days I have solved, at least for me, the issue. The stock weather app continues to use your location in the background regardless if you have it enabled for background or not. It will also cause location services to be used when you open notification center even if you disable everything disabled in Today View in notification center. I disabled location services for the stock weather app and literally my battery drained a lot slower.
You can test it out by opening your notification center. You will see location services being used if you have location enabled for the weather app. Disable it and then try again. No location icon when you open notification center.
I'm using the yahoo weather app for now, but I will also submit it ti apple. Hopefully it gets fixed soon.
