Jailbroken iPhone 4s stuck in the setup phase after downloading iOS 7. Help.
kate coghetto
Sep 19, 2013
I have a jailbroken iphone 4s, i had to restore when downloading ios7, now it's stuck in the initial "set up" phase.
Any ideas of what I could do?
Thanks!
59,710
633
If you're certain your device is no longer jailbroken then put your device in DFU mode and try again, but if you're unsure, be a bit more patient and wait for one of the jailbreak specialists to chime in with some advice/instructions.
natasftw
1,355
It's the same advice either way.
CØR
