1. Brandon32's Avatar
    Other than the Insomnia tweak, is there another tweak that keeps your wifi connected when it's locked and on battery?
    02-20-2013 06:08 PM
  2. kch50428's Avatar
    As was discussed here: http://forums.imore.com/iphone-5/250...r-vs-wifi.html - Wifi isn't really disconnected when a device is locked - it's in a "hot standby" and is not a bug - it's a feature designed to help save battery.
    02-20-2013 06:28 PM
  3. rhferg's Avatar
    I have the same question.
    Please don't tell me that it's not a bug or how it is saving my battery. I am not complaining about this feature, I just need to find a way round it. I want my phone to sleep and stay connected to the wifi.
    My best answer so far is to tune into a radio station using a radio app. Because it keeps streaming, the wifi is left on. However, something like an incoming call will probably switch off the app, so it's only a partial solution.
    03-18-2014 08:03 AM
  4. kch50428's Avatar
    03-18-2014 08:50 AM
  5. acerace113's Avatar
    Mine stays connected to wifi with iOS 7...
    Sent from my iPhone 5S or 5th gen iPod Touch using Tapatalk
    03-18-2014 10:04 AM
Similar Threads
  1. iPad 3 - iTunes not detecting and not charging
    By Soulrez in forum iPad Series
    Last Post: 12-04-2014, 06:30 PM
  2. Replies: 2
    Last Post: 10-05-2012, 08:42 AM
  3. iphone not charging with both pc and wall charger
    By piyashrija in forum iPhone 4
    Last Post: 05-29-2012, 08:42 AM
  4. when you lose your wifi connection?
    By jwsnj3rd in forum iPhone 4S
    Last Post: 01-14-2012, 01:42 PM
  5. Replies: 0
    Last Post: 12-19-2009, 07:58 AM
