Advanced User Needs Help With Upgrade / Restore Issues
MPIIIMan
Jun 16, 2009
42
www.mpiiiman.com
Hello,
I have been working on updating my iPhone 4 since the release of iOS5 yesterday.
I wanted to do a clean restore so I simply downloaded the IPSW and Shift + Click to do the restore.
I keep receiving the same error: The iPhone "iPhone" could not be restored. An unknown error occurred (14)
I have tried to do the following to remedy the problem:
  1. Put the phone in DFU mode and tried restore. Same error
  2. Uninstalled / Reinstalled iTunes
  3. Tried using different USB ports
  4. Tried using a USB hub with it's own power
  5. Re-Downloaded the .IPSW firmware file
  6. Made sure all Windows Updates were up to date
  7. Tried 4 different computers. 3 PC's and 1 MacBook. Same error on all computers.
  8. Tried using TinyUmbrella's "Fix Recovery" tool
  9. Tried disabling my anti-virus / firewall
  10. Tried to reset my TcpWindowSize packet size per Apple Support
  11. Tried a different USB 30 Pin Connector cable
  12. Made sure my "hosts" file did not have the TinyUmbrella entries for gs.apple.com
  13. I have successfully restored my phone to 4.3.5 and then tried the normal upgrade method to 5.0. This failed with the same error (14)
  14. Went into Services and tried restarting Apple / Ipod services
  15. Google'd high and low looking for a solution and nothing is helping.
I originally thought my phone had some serious issues, but when I was able to restore to 4.3.5, I doubted it's an issue with the phone.
Next step would probably consist of making an appointment with Apple Genius Support (Really don't want to do that seeing as the 4S will be out tomorrow and the stores will be slammed)
I have exhausted all possible solutions that I know of. I would really love some expert help.
big9erfan
2,458
35
Did you try doing a restore on another computer just to see if it worked? Yes, I know you mentioned that it restored 4.3.5 without issue, but it's worth a shot right?
MPIIIMan
Jun 16, 2009
42
www.mpiiiman.com
Yes I've tried restoring on the following:
Home MacBook
Home PC1 - Windows 7 - 64 Bit
Home PC2 - Windows 7 - 32 Bit
Work PC3 - Windows 7 - 32 Bit
I'm getting ready to try a Windows XP computer in a few minutes.
My phone currently has 4.3.5 on it, so I'm simply going to try doing an upgrade on that computer and see what happens.
EvilJack
127
12
Wow. I looked through your list and you've done everything and more. I'd say to give up at this point unless you have nothing better to do. The result is not worth that much trouble. Go to the Genius Bar today. Tomorrow would not be good.
MPIIIMan
Jun 16, 2009
42
www.mpiiiman.com
Apple replaced my phone. It was even 100 days out of warranty.
I think they felt bad because I printed out all the things I tried and brought it with me.
Smooth sailing now on my new iPhone 4 :-D
smitty22d2
