Help with signal strength replacement
Hi All,
Just jailbroke my ip4 yesterday and am starting to customize everything on my phone. I've haven't owned an iphone in a while, so I'm sorry if it's a n00b question:
I'm trying to replace my signal strength/wifi bars with "Retina Signal and Wifi", but for some reason, they're not appearing even though they're checked off in winterboard. I've brought the 2 "themes" to the top of the winterboard, resprung, even did a hard reset; nothing. Help? any suggestions? I do have a UI theme installed, but it doesn't touch the status bar, all signal bars, etc are currently "stock."
Thanks!
