Time to upgrade! Get an iPhone 12 mini + Unlimited Data for $60/mo
- My results after charged to 100%, disconnected and left phone overnight in standby (8 hours):
(Greenpois0n rc5 b2 with just lockinfo and sbsettings instaled, no plug-ins)
on b2: one morning 84%, second time 80%.
Restored yesterday, on pure 4.2.1: 97% in the morning.
I will update this when I JB with b402-10-2011 06:35 AMLike 0 - Ha, sucks. I literally took a deep breath and my anxiety level rose a little when I was doing the B4 over the B2. I almost flat-lined when my phone was stuck on the little skeleton startup thing when it was done. I just did a hard reset and then it booted up like normal. Literally almost freaked out. haha02-10-2011 11:44 AMLike 0
"Restore as New device"... (time consuming i know, but worth it) then jailbreak with RC6 Final. i did this last night and it has worked out great, as i was dealing with a little battery drain from running on top like your considering
once again, not sure why the jailbreak itself would cause any type of battery drain.. i loaded all the same apps/tweaks as before. odd
let us know what you think02-15-2011 11:02 PMLike 0 - iVenom
My iphone is a 3GS running 4.2.1 and wasn't previously JB. Started with b2 version of GP then I did the b4 build on top of that due to claims of better battery life.
Next question is I assume that I need to make notes of what Cydia stuff I've installed (and purchased) so that I can redo them after the JB and sync? I assume that Cydia keeps up with my purchases (biteSMS, etc)?02-16-2011 09:52 AMLike 0 - I can say that my battery life is slowly getting back to what I consider normal. It's been a week and a half since I JB, and I am now getting home with 40% battery. That's up from having to charge it on the way home. It is coming along nicely. I'll just have to wait and see if I can get home from work, 12 hours after unplugging it and be at 70% like I used to.02-16-2011 02:47 PMLike 0
- BLiNK, I'm still not thrilled with my battery life after JBing and then putting b4 on top of b2 (I know I got the phone doing more stuff than before -- way better stuff though) but still the life of the battery is not what I would like. So you are saying to Restore the phone as a new device in iTunes first. Do you then Sync it in iTunes to get your stuff back, and then JB using the most recent GP build? Or JB it then Sync?
in fact, right after i "restored as new" i jailbroke right away just in case something were to go wrong.... then go ahead and sync your photos, music, apps etc
typically, when i do any type of restore i will hand write all my apps/tweaks from my packages section in cydia and manually load them. some people use backup apps and such but i ran into issues in the past
i have noticed a BIG difference every time i "restored as new" in regards to my battery life. i am glad that this is the final release of greenpois0n (4.2.1) as my device is set up perfectly..
after you do this please let me know how it worked out for you02-16-2011 03:20 PMLike 0 - Thanks BLiNK. I appreciate the very detailed response. I'll give that a try as soon as I can dedicate time for it.
I did find an app called 'AptBackup' that claims to restore your Cydia apps. Free so figure I'd give it a shot but I definitely will take some notes on what I have already. thanks again and I'll post an update.02-16-2011 09:07 PMLike 0 - Ok I just ran gp final on top and it seems to be working better. I got 7.5h use and 17h standby today so with all the same apps except my3g this is about right for me. I'm not saying it will work for all but I'm good with my battery life now. Thanks if I hit any other problems I'll restore from new.02-17-2011 04:26 AMLike 0
- Forum
- Apple Software & Systems
- iOS
Greenpois0n JB battery problem
