Problem jailbreaking - is it possible?
DucoNihilum
Aug 3, 2010
I'm using a 3GS that came with 3.1.3 (I assume new bootrom), I'd like to install 4.0 jailbroken. So far I've gotten to the point where I realize I might need 3.1.2, however, it's impossible for me to do so without SHSH, which I don't have because I've never used cydia on this device.
Can I still jailbreak this? Is there a workaround?
w00dy
211
7
Short answer: yes
is it worth the risk (not at this time): no
spirit jailbreak would be a better alternative for you
peanutgallery
132
www.thepeanutgallery.net
Spirit would work to jailbreak his 3.1.3 but the OP wanted to jailbreak 4.0.1.
So if you want a jailbroken 3.1.3 you can use spirit, so long as you are using iTunes 9.1. If you upgraded iTunes you'll need to find an old install file for 9.1.
If you want a jailbroken 4.0 / 4.0.1 you'll need to use jailbreakme.com
smitty22d2
