Originally Posted by
norcalsherri I have a 3Gs 3.1.3
MY phone was jailbroken before...but something happened..not sure what..and my phone had to be restored to its original condition ...i then restored a back up. So I downloaded Blackrain..had my phone plugged in...I run Blackrain..it will then say entering recovery...then running...then I get the message that my phone has been jailbroke...and it says wait for reboot...well it gets stuck there...and wont reboot...my iphone screen is not completely black you can see a little light on it.. if I do a home and turn off my phone or just turn off and turn on..it is not jailbroke...any suggestions?
Thank you!
Sherri
I have also done this without my itunes being open
I know what happened! After you restored your iPhone, iTunes automatically updated your firmware to 3.1.3 because you need to turn of automatically update in your iTunes settings. If you had your SHSH's on file with Cydia like you said you will be able to downgrade to 3.1.2 & rejailbreak. First thing you should is turn off auto updates in your iTunes settings. I'm sure by now you have read what could have happened to your iPhone if you upgraded to 3.1.3 without having restored back to normal. Glad to hear this is not what happened, I know I seen somewhere how to get 3.1.2 back. I will post it asap, when I get to my pc. Unless somone beats me to it, BRB!
