1. peterr22's Avatar
    Has anyone done this? I'm tried many different things and cant send or receive MMS.
    Ive googled till my eyes started hurting so..HELP
    just to clarify i have attached a picture
    I have a 2g unlocked/jailbroken
    prepaid TMOBILE sim card
    MMS2G installed and working
    I need the correct network/carrier settings
    07-16-2009 05:45 PM
  2. peterr22's Avatar
    ok i kept searching and here is what i found
    shinbo.wordpress.com/2009/06/29/woot-stock-mms-hacked-onto-my-iphone-2g-on-tmobile/
    APN: epc.tmobile.com (Make sure this APN is the same as the “Cellular Data” APN above or else it won’t stick) (Other people use other APNs and claims it works too (wap.voicestream.com or something, I’m just posting whatever works for me)
    Username: (Intentionally Blank)
    Password: (Intentionally Blank)
    MMSC: mms.msg.eng.t-mobile.com/mms/wapenc
    MMS Proxy: 216.155.165.50:8080
    07-16-2009 10:11 PM
