How to "Hide" battery when charging?
Dealwagon
54
Is there a way to make the battery screen show cover art, and not the battery when carging and playing ipod tunes? I use it in my car and would MUCH rather see cover art than a battery.
Bonus question for extra credit..
Is there a way to make the screen stay on while charging?
Jailbreaked 1st gen iPhone. Software is latest official from the mothership.
Ghecko
201
6
You can search thru finder for the battery charging pictures if you remove those, then you should be solved..... i dont get your second question re-explain plz
INTERNET BUNDLE NOW
