1. lawful73's Avatar
    hello, In Noise Control: what is the difference between Off and Transparency? thank you.
    Annie_M likes this.
    11-10-2019 08:36 PM
  2. Al Paca's Avatar
    https://support.apple.com/en-us/HT210643
    Hopefully this helps...in short it helps determine how much outside noise gets through.
    lawful73 likes this.
    11-10-2019 09:33 PM
  3. lawful73's Avatar
    Thank you, so if you are listening music, it is better Off than Transparency?? I mean less outside noise?
    11-10-2019 10:21 PM
  4. TripleOne's Avatar
    Transparency should have less outside noise.
    11-11-2019 04:27 AM
  5. lawful73's Avatar
    Thank you. Could you please explain why?? Apple says “ Transparency mode lets outside sound in, so you can hear what's going on around you.”
    11-11-2019 06:36 AM
  6. Spencerdl's Avatar
    I tried to post the Apple Airpods Pro information and video, but for some reason the system would not let me. Just go to the Apple site and you will see it on the very first page. The explanation to your question is there.
    11-11-2019 08:03 AM
  7. Just_Me_D's Avatar
    11-11-2019 06:12 PM
  8. lawful73's Avatar
    Thank you but it doesn’t say the difference between Transparency and Off and which one is better for listening to music (besides Noise Cancelation).
    11-11-2019 06:16 PM
  9. Just_Me_D's Avatar
    AirPods Pro Noise Control-img_0309.jpgAirPods Pro Noise Control-img_0308.jpg
    Spencerdl likes this.
    11-11-2019 06:19 PM
  10. lawful73's Avatar
    Click image for larger version.
ID:	127584Click image for larger version.
    And Off? I still don’t understand why they made 3 options instead of 2 (Noise Cancelation and Transparency). I don’t understand the difference between Off and Transparency.
    11-11-2019 06:23 PM
  11. Just_Me_D's Avatar
    “The way the Transparency mode works is by leaving on the part of Active Noise Cancellation which is focused on eliminating internal sound. So, when you wear the AirPods in Transparency mode, you're not getting the full noise-canceling effect. Rather than having to turn your volume all the way up to block out loud noises, you'll be able to listen to whatever you want at a comfortable volume while still being aware of your surroundings.”
    Source: https://www.elitedaily.com/p/what-is...seful-19281528
    That means there is no active noise cancellation at all in OFF mode.
    Spencerdl, lawful73 and Annie_M like this.
    11-11-2019 06:29 PM
  12. lawful73's Avatar
    Thank you!! Super clear.
    Spencerdl and Just_Me_D like this.
    11-11-2019 07:59 PM
  13. Spencerdl's Avatar
    Thanks for the explanation/information JustMeD. I'm on my way to pick up a pair right now...LOL
    Annie_M and Just_Me_D like this.
    11-11-2019 08:03 PM
  14. GibMcFragger's Avatar
    Transparency mode uses the microphones to pass outside sounds through, so you can hear your surroundings.
    Active noise cancellation actively cancels out surrounding sounds electronically, so you hear nothing (basically) but the music.
    Off is just that. Active noise cancellation is off, and so is the Electronic pass through (transparency).
    With off, you will get some outside noise blockage due to the ear cup seals, but not nearly as good as with the active noise cancellation on.
    Annie_M, Spencerdl, Mars20 and 2 others like this.
    11-15-2019 12:33 AM
  15. lawful73's Avatar
    Apple offers a transparent mode option that allows users who are concerned about active noise reduction to eliminate sounds to listen to the surrounding environment. Transparent mode utilizes the ventilation system in AirPods Pro to reduce active noise reduction. AirPods Pro users can not only listen to traffic and radio, but also listen to music and podcasts at the same time.
    Thank you. Very clear.
    11-15-2019 02:30 PM
  16. lawful73's Avatar
    Thank you for your explanation.
    11-15-2019 02:31 PM
  17. ItnStln's Avatar
    Thanks for the explanation!
    11-25-2019 04:17 PM
  18. imwjl's Avatar
    In my short time with these and with some hearing loss I actually hear some mid and high frequencies better transparency on.
    12-20-2019 02:05 PM
  19. Spencerdl's Avatar
    I totally agree. A hidden bonus
    imwjl likes this.
    12-23-2019 08:40 PM
  20. Annie_M's Avatar
    I am really appreciating this thread- it is very helpful!
    01-07-2020 09:32 AM
  21. Spencerdl's Avatar
    Transparency mode acts almost like a "hearing aid"...I always keep it on when my AirPods Pro are in my ear(s), unless I'm listening to music.
    01-07-2020 09:42 AM
  22. imwjl's Avatar
    [IMG=473x1024]https://uploads.tapatalk-cdn.com/20200107/c79f53481e2c9f827239244fa2285abd.jpg[/url]
    I tried my mother's $3000 hearing aids. The AP Pro has better fidelity. In our HQ office I hear over desk dividers or sit working in the c suite conference room and hear things outside the door that would not happen without them.
    I do know I have some hearing loss and bad tinnitus but for now will use the AirPod Pros before I get hearing aids.
    These create other wonderful effects in transparency mode. Last week I was on a bus in another country. The combo of local music from my phone, hearing what was going on in the bus, the feel and the sights made it like a living movie and sound track better than a director or theme park engineer could do.
    Annie_M and Spencerdl like this.
    01-08-2020 08:05 AM
  23. Annie_M's Avatar
    I tried out transparency mode yesterday as I worked in my office. I can definitely understand now why this is such a great option.
    01-08-2020 09:37 AM
  24. bamf-hacker's Avatar
    Off is like the regular AirPods. Noise Cancelling, samples the noise in the environment and try to get rid of the background noise. Transparency lets outside noise in so you can hear the surroundings.
    01-08-2020 09:39 AM
  25. Spencerdl's Avatar
    So I had to get another set of AirPods Pro and it seems as though the transparency mode isn't as robust and transparent as my first set. I'm not sure if it's just me and my weird ears. Has anyone else experienced this?
    12-02-2020 08:28 PM
27 12
Similar Threads
  1. Which MacBook Pro is better?
    By torbjornhb in forum MacBook Pro
    Last Post: 11-10-2019, 09:20 AM
  2. Roku launches Apple Watch app with remote, channels, and voice control
    Last Post: 11-09-2019, 11:30 AM
  3. Calvin Harris flashes new Mac Pro in Instagram Story
    Last Post: 11-09-2019, 09:40 AM
  4. Carfection filmed a video shot entirely on iPhone 11 Pro
    Last Post: 11-09-2019, 07:22 AM
  5. Sennheiser's HD 4.50 SE Wireless Noise-Cancelling Headphones are now $80
    Last Post: 11-08-2019, 04:00 PM
