Has anyone had this issue and know how to fix it? I’ve done the obvious like making sure they are clean and disconnecting and re-pairing them but the volume is still very low even when turned all the way up.
Use a (old) toothbrush to clean the protective mesh in the AirPods.
I had that done at the Apple Store and the difference was like day and night.
Hadn’t thought of that. I’ll give it a shot. No solvents or anything right. Just a dry toothbrush?
Do you have Volume Limit enabled? Go to Settings>Music and it’ll be near the bottom.
Totally worked! Didn’t even appear that anything came out of it but the difference is night and day. Thanks for the tip
