Help pls! Right AirPods drain in the charging case?
bonjourxx
May 27, 2016
12
Hello. So since I got my AirPods I noticed that my right airpod doesn't stay 100% while in case and drains to 75% instead. My left one doesn't have a problem and is always 100% when not in use and in the charging case. I used it all day couple of days ago to drain the battery hoping it will get fix, both got fully charged to 100%. now when I was planning to use it i opened the case, it says that left is 100% again but right AirPod is 75%. Is this broken? Why does the right AirPod doesn't stay 100% while in the case and drains? :/
Tartarus
Feb 20, 2014
17,442
20
Please make sure there is no dirt, dust or any lint in AirPods case. Wipe the silver contacts at the end of your right AirPod off with a soft cloth.
If this doesn't fix the issue, try unpairing and repairing the AirPods.
59,784
645
I the recommendation by Tartarus doesn't fix the problem, make a Genius Bar appointment with the nearest Apple Store and have them check it out for you.
smitty22d2
