Welcome to the iMore Forums Create Your Account or Ask a Question Answers in 5 minutes - no registration required!
Results 1 to 9 of 9
Like Tree4Likes
  • 1 Post By fabio984
  • 1 Post By firedept10
  1. Thread AuthorThread Author   #1
    fabio984's Avatar
    iMore Intermediate
    Posts
    Global Posts
    737 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default [HELP] Macbook Pro USB right port not charging iPhone
    Hi, I'm a happy owner of a new macbook pro 13" retina.(I'm loving this machine).
    The problem is:
    when I plug the USB (original cable) to the left USB port, the iPhone (5S) battery charges perfectly, but when I plug it to the right side USB port, it keeps connecting and disconnecting (with that charing sound repeatedly "plum plum plum plum plum") ...
    Any help? This is very annoying. And I'm worried because the computer is brand new.
  2. #2
    firedept10's Avatar
    Posts
    Global Posts
    4,900 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: [HELP] Macbook Pro USB right port not charging iPhone
    Quote Originally Posted by fabio984 View Post
    The problem is:
    If it is brand new, then there could be a problem with the port. I would suggest since it is new and hopefully under warranty, to take it into Apple to have it looked at. If you do bring your cable and phone so you can reproduce it foe the Apple Genius. You can also check to see if there is not any dirt in the port.
  3. Thread AuthorThread Author   #3
    fabio984's Avatar
    iMore Intermediate
    Posts
    Global Posts
    737 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by firedept10 View Post
    Well, that sucks. I emailed apple pro, and asked apple support to call me tomorrow too, let's see what they say.
    And I'm waiting to see if someone here have or had this problem too.
    firedept10 likes this.
  4. #4
    firedept10's Avatar
    Posts
    Global Posts
    4,900 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I have seen and read of this issue many a time. It happens unfortunately. Hopefully someone can offer more suggestions for you.
    fabio984 likes this.
  5. Thread AuthorThread Author   #5
    fabio984's Avatar
    iMore Intermediate
    Posts
    Global Posts
    737 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    If I knew that they'll give me a new computer, I don't mind.
    My problem is imagine that they'll open the computer to fix the problem. This computer hasn't 1 month yet.
  6. #6
    firedept10's Avatar
    Posts
    Global Posts
    4,900 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Don't worry, Apple will do a good job. You won't even know it was opened. I had a bad iMac one time and was in for service 5 times before they replaced it. And I could never tell it had been opened. I wouldn't count on a replacement if it is only a usb repair. That is actually a very simple repair for them. Apple are very good at standing behind their devices, that why you pay a premium price for them. Good luck and I hope it all works out for you!
  7. Thread AuthorThread Author   #7
    fabio984's Avatar
    iMore Intermediate
    Posts
    Global Posts
    737 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I found something and I think it helped!
    google dthe problem and found this link: Mac USB Ports Stopped Working? It?s Likely Easy to Fix | OSXDaily
    You don't need to open it. What I did was "the NVRAM Reset"
    All I did: restart the Mac, and immediately hold down Command + OPTION / ALT + P + R keys together.
    The phone is plugged and charging fine(10minutes. It didn't charged 1 minute before this) ! I'm so happy!!!!!!!!!!!!!!!!!!
    Hope this helps others...
    I'll update this topic if something changes!
    print screen from the website:
    Click image for larger version.
Name:	Captura de ecr
  8. Thread AuthorThread Author   #8
    fabio984's Avatar
    iMore Intermediate
    Posts
    Global Posts
    737 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    The problem is back...
  9. Thread AuthorThread Author   #9
    fabio984's Avatar
    iMore Intermediate
    Posts
    Global Posts
    737 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I think the problem is the iPhone. It only happens with mine.
Similar Threads
  1. Do cases exist for the iPhone SE Battery and SD Card?
    By Shandybang in forum Ask a Question
    Last Post: 11-22-2016, 12:29 PM
  2. Replies: 16
    Last Post: 10-18-2016, 06:40 PM
  3. New Apple watch owner - message app
    By jobosumm in forum Apple Watch Apps & Games
    Last Post: 10-17-2016, 07:32 PM
  4. iPhone 7 plus font very small
    By squill in forum Ask a Question
    Last Post: 10-16-2016, 03:52 PM
  5. How can I unlock apple watch by iphone touchID?
    By Ganesh Vu in forum iPhone 6s
    Last Post: 10-16-2016, 07:35 AM
Posting Permissions
