my MacBook pro was purchased in 2009 recently it indicated a battery low problem ,it works well with the powersupply adapter , i usually update my mac presently it has the , ios5.? update , what should i do to fix this problem also the battery counter has a malfunction it would indicate 80% then down to 32% within 5mins the actual condition of the mac is excellent need some help urgently.
