Welcome to the iMore Forums Create Your Account or Ask a Question Answers in 5 minutes - no registration required!
Results 1 to 2 of 2
  1. Thread AuthorThread Author   #1
    igo is offline
    igo's Avatar
    iPhone Nanite
    Default Changing SMS sound settings/Sound settings
    How do I get the phone to Vibrate for Texts/Calls when the sound is off!?
    Also, I don't want a sound for text, I just want a Vibrate!
    How do you do this with a jail broken phone? since you cant do it stock!?
  2. #2
    Jheri's Avatar
    iPhone Newbie
    Global Posts
    35 Global Posts
    You can do this stock. You just go to setting, then sounds, then select on for Vibrate, and then select none for you text tone.
    Edit: I'm not sure selecting none is the right option for what you want. I would just turn vibrate on and then keep the phone on silent.
Posting Permissions
