Welcome to the iMore Forums Create Your Account or Ask a Question Answers in 5 minutes - no registration required!
Results 1 to 13 of 13
Like Tree16Likes
  • 2 Post By Tartarus
  • 1 Post By libra89
  • 4 Post By Ledsteplin
  • 3 Post By Paul1266
  • 1 Post By libra89
  • 2 Post By Rob Phillips
  • 1 Post By libra89
  • 2 Post By Thanhnyx
  1. Thread AuthorThread Author   #1
    Thanhnyx's Avatar
    iMore Newbie
    Posts
    Default Iphone SE Battery Max Capacity Issue
    My Iphone SE has this issue: Max Capacity is 1600mAh, but max charge only 1000 mAh, battery drains real fast. Anyone can help me!!!! I've use this phone for 2 weeks, and charge with Apple US charger.
  2. Thread AuthorThread Author   #2
    Thanhnyx's Avatar
    iMore Newbie
    Posts
    Default Re: Iphone SE Battery Max Capacity Issue
    Click image for larger version.
    Information from Battery Life. Thanks for helping.
  3. #3
    Why would you need a battery app for a few-weeks-old-device??
    Max charger is the current of your charger, not what the battery can hold.
    Your battery capacity is 1600 mAh.
    Your battery drains only fast because you are playing with it constantly. That is normal. Depending on what apps you're using the drain will be faster or slower. This is just how batteries work.
    Like cars, the higher the speed, the sooner the gas need.
    Delete that app and enjoy your SE.
    libra89 and Thanhnyx like this.
  4. #4
    libra89's Avatar
    iMore Pro
    Posts
    Global Posts
    5,113 Global Posts
    I'm curious what is meant by fast battery drain. As Tartarus said, this strongly depends on apps.
    Facebook is a known drainer, along with some others. I don't know why Facebook just sucks.
    Thanhnyx likes this.
  5. Thread AuthorThread Author   #5
    Thanhnyx's Avatar
    iMore Newbie
    Posts
    Thanks, but as my feeling, battery runs fast at 100%-80%, much slower at below 80.
    It lasts longer at 100% down to 99%.
  6. #6
    Quote Originally Posted by Thanhnyx View Post
    Not really. It just appears that way. It's like having a full tank of gas. Seems to last a long time on full. But seems to go faster the lower the tank is. The issue is the % indicator in the status bar. Try calibrating it by running the battery down to 1%, then charge it up to 100 % with no breaks.
  7. #7
    Paul1266's Avatar
    iMore Nanite
    Posts
    Global Posts
    256 Global Posts
    I think you will find most batteries are not actually the 1600 mah advertised. They will vary but probably exceed the advertised capacity by anything up to 50-60 mah. Therefore, the phone will not register a drop below 100% until it hits 1584mah. In reality the phone will have used far more than 1% of the 'true' battery capacity. This isn't unique to iPhones, old Windows phones used to take an age to drop from 100%. I get almost an hour of usage on my new SE before it falls to 99% it then seems to fall a quicker (relatively anyway) but steady rate.
    Tartarus, Thanhnyx and libra89 like this.
  8. Thread AuthorThread Author   #8
    Thanhnyx's Avatar
    iMore Newbie
    Posts
    hmm, understand. so anw, the charging method like, charge 8hrs at the 3 first times, is not necessary?? or empty the battery, keep it unused for 2hrs and then charge for 5-8hrs every month? too many advice and im confused @.@"~. btw, thanks for advise!!
  9. #9
    libra89's Avatar
    iMore Pro
    Posts
    Global Posts
    5,113 Global Posts
    To me, that sounds like a lot of additional work. It's much easier to just charge when you'll like to. I have heard continuously that you should try to avoid using a full charge cycle (0-100%) as much as you can, because that's horrible for the battery.
    Personally I put it on the charger at 30-35% because that stops it from using a full charge cycle. 0-100% is good for calibration every once in a while if you'll like to, or you feel like your battery is not showing the correct percentage, but no more than that. As said, it's much easier to just charge when you want to.
  10. Thread AuthorThread Author   #10
    Thanhnyx's Avatar
    iMore Newbie
    Posts
    Quote Originally Posted by libra89 View Post
    Hi Libra, u mean, never or avoid charging full 100%??, like 99% or below and discharge??
  11. #11
    I personally don't see an issue with it, although you should avoid leaving it plugged in for days at a time. I've been charging iPhones overnight for six years and have yet to experience a battery issue.
  12. #12
    libra89's Avatar
    iMore Pro
    Posts
    Global Posts
    5,113 Global Posts
    I think there was a misunderstanding of my words. My apologies.
    What I meant by the 0-100% comment is letting the battery go down to 0% (or completely die) and then charge it back up to full on a regular basis. Letting the battery go down to 0% isn't good to do all the time.
    You should charge to 100%, nothing is wrong with that. Do what is best for you.
  13. Thread AuthorThread Author   #13
    Thanhnyx's Avatar
    iMore Newbie
    Posts
    thanks alot for all your advices. Now stop worrying and enjoy the little SE hehe.
    <3
    libra89 and Tartarus like this.
Similar Threads
  1. 64GB space gray SE with Applecare+
    By pappy53 in forum Marketplace Archive
    Last Post: 07-29-2016, 01:58 AM
  2. Can't unjailbreak my iPhone 6 - iOS 9.3.3
    Last Post: 07-27-2016, 09:53 PM
  3. Jailbreaking iPhone 6s
    By lewiswatson55 in forum Jailbreaking, Unlocking, Hacks, Themes & Mods
    Last Post: 07-27-2016, 01:52 AM
  4. how do i pull up the telephone dial pad in iphone 6s?
    Last Post: 07-27-2016, 12:56 AM
  5. iPhone sales in India up by 51% YoY
    By iMore.com in forum iMore.com News Discussion
    Last Post: 07-27-2016, 12:51 AM
Posting Permissions
