Welcome to the iMore Forums Create Your Account or Ask a Question Answers in 5 minutes - no registration required!
Results 1 to 15 of 15
Like Tree6Likes
  • 1 Post By kch50428
  • 2 Post By warcraftWidow
  • 1 Post By SeanHRCC
  1. Thread AuthorThread Author   #1
    gameson's Avatar
    iMore Intermediate
    Posts
    Global Posts
    1,060 Global Posts
    Default Does minimizing apps on the background (double tap the home button) help battery life?
    Just wondering. If I close or minimize number of apps running on the background (double tap the home button) will help in battery life? Or it's a placebo effect?
    Thanks.
  2. #2
    rdiddy_25's Avatar
    iMore Genius
    Posts
    Global Posts
    4,305 Global Posts
    Default Re: Does minimizing apps on the background (double tap the home button) help battery life?
    Quote Originally Posted by gameson View Post
    Thanks.
    Not anything you'll notice. It will help your memory more tho.
  3. Thread AuthorThread Author   #3
    gameson's Avatar
    iMore Intermediate
    Posts
    Global Posts
    1,060 Global Posts
    when you said memory, you mean RAM? or storage space?
    Thanks.
  4. #4
    tech_fan's Avatar
    iMore Intermediate
    Posts
    Global Posts
    960 Global Posts
    It was always my understanding that closing the apps that run in the background will save battery life and when I try it, I do notice an increase in battery life.
  5. #5
    kch50428's Avatar
    iMore Genius
    Posts
    Global Posts
    21,872 Global Posts
    Thanks.
    Mostly placebo. Unless the app is written to use GPS and continue to do so while suspended to background. Those will use battery.
    Jaguarr40 likes this.
  6. #6
    rdiddy_25's Avatar
    iMore Genius
    Posts
    Global Posts
    4,305 Global Posts
    Thanks.
    RAM, has nothing to do with storage space
  7. Thread AuthorThread Author   #7
    gameson's Avatar
    iMore Intermediate
    Posts
    Global Posts
    1,060 Global Posts
    I see. I guess if you are playing a game that requires data (cellular or wifi) connections and/or GPS (i.e CSR Racing, Hay Day, Google Maps, Around Me or such), it would affect the battery, but if it's standalone app (i.e Angry Birds), then it should be OK.
    Is that right?
    Quote Originally Posted by kch50428 View Post
  8. #8
    kch50428's Avatar
    iMore Genius
    Posts
    Global Posts
    21,872 Global Posts
    Is that right?
    Yep.
  9. #9
    warcraftWidow's Avatar
    Banned
    Posts
    Global Posts
    8,342 Global Posts
    Other apps that run in the background would be audio (Pandora) and VoIP (Skype) apps. Most most apps are in a suspended state and use no processor. They may or may not use any RAM but if the operating system determines it is needed for another app, the suspended app is forced to give it up.
    kch50428 and Jaguarr40 like this.
  10. #10
    TurboTiger's Avatar
    iMore Elite
    Posts
    Global Posts
    7,095 Global Posts
    I close mine from the multi-task bar all day long.
    My wife iPad has locked up on several occasions and closing out the apps fixed the issue. Yes had a ton o close out.
    Good Luck
  11. #11
    Banned
    Posts
    Global Posts
    8,342 Global Posts
    The app tray is really a "most recently used" app list, not a list of apps currently running.
  12. #12
    SeanHRCC's Avatar
    Banned
    Posts
    Global Posts
    12,215 Global Posts
    At times certain apps (even when "closed") will still access your locations service (GPS) which can and does drain battery life, but for the most part, it should only last few maybe a minute at most and then stop (sometimes apps will have issues where this is not the case, but i know at least on my phone, any app that had this issue no longer does). Games can sometimes get wonky and stop responding (or get stuck in a load loop), closing them out will rectify this almost all the time (and it really has more to do with the game trying to connect to the network of the developer than the phone itself)...this can, sometimes, cause performance issues though that would call for closing out in the multitask bar.
    Other than that though, it really doesn't have a dramatic effect in any way, shape or form...and does not really effect battery life noticeably.
  13. #13
    gordol's Avatar
    iMore Expert
    Posts
    Global Posts
    1,158 Global Posts
    Quote Originally Posted by Karenkcoulter View Post
    And yet, I and others have noticed, and reported in these forums, that there is a noticeable difference in battery life between clearing it out and letting everything you open ever remain in that task switcher.
  14. #14
    Banned
    Posts
    Global Posts
    8,342 Global Posts
    Quote Originally Posted by gordol View Post
    So some people sayI've never noticed a difference one way or the other myself though. And yes I've tried clearing out the task switcher.
  15. #15
    Nolander07's Avatar
    iMore Intermediate
    Posts
    I used to do it all the time, but I have stopped and I have not noticed any difference in battery life or speed of the phone in the last few months. I must say it is quite liberating not thinking about closing apps all the time.
Similar Threads
  1. Home button double tap resets phone, please help!
    By toreroguysd in forum iPhone 4S
    Last Post: 04-11-2012, 12:26 AM
  2. New app on store! (Do You Have The Power)
    By Sparhawk811 in forum iPhone Apps & Games
    Last Post: 07-19-2011, 06:31 PM
  3. Changing the background on my iPhone? (behind the app icons)
    By King Mustard in forum Jailbreaking, Unlocking, Hacks, Themes & Mods
    Last Post: 02-28-2010, 06:37 PM
  4. Child Identification app on the iPhone
    By lgndsftwrgrp in forum iPhone Apps & Games
    Last Post: 04-14-2009, 08:52 AM
  5. Replies: 3
    Last Post: 09-22-2007, 03:38 PM
Posting Permissions
