Just curious as I read a comment somewhere that it isn't good to use a battery case as it can damage the original battery.
p2kart and wrxnfx that makes sense. However if the battery is at 100% or close to it, it should power it without charging it. The external battery I have says using it is one way to save and prolong your battery. I am not sure if that is just marketing hype.
