PLEASE help - major problem with iPhone 3G!!
Status
Not open for further replies.
tulliver
Jan 26, 2009
41
I have a jalibroken iPhone 3G running firmware 3.0 and its locked on O2.
Recently for some reason I've noticed that the signal on my iphone is totally screwed. I can only get signal if my iPhone gets 3G signal; but if it only gets EDGE or GPRS then the little icon (o or E) comes up but no bars and you can't call/text. Also, if I lose my 3G signal I have to restart the iPhone to get it back.
Please help, I don't want to restore :( tia
mikeypascual
Sep 18, 2009
Ohh ouch
Wow, that would be really bad! You should restore it and take it to your nearest Apple Store with a friend and they should replace it on the spot. They're good like that ;) x
Status
smitty22d2
