iOS 9.3 beta public on iPad Pro - no pencil scrolling problem. Has anyone else had this problem?
Trigati
209
But there's no reason they need to remove the additional functionality that exists currently in 9.2.
If I'm already using the pencil I now have to put it down or switch my grip on it if I want to scroll or tap? Or for some people who might actually need to use a stylus type device for some reason, instead of just buying an apple pencil and being done with it, they now have to buy two additional things?
Sorry, but it's a load of BS if they're actually removing functionality and this isn't just a bug.
Haalcyon
865
Re: iOS 9.3 beta public on iPad Pro - no pencil scrolling problem
What does Apple gain by disallowing the Pencil to be used for navigation?
samcochrane
Mar 29, 2013
This is fairly off-topic here, but I'll brave the waters and ask anyway:
If I install the public beta of 9.3, when the general release comes out, will I be able to OTA update to that build without any data loss?
dave1704
Feb 14, 2016
It is dawning on users that this is not a bug, but a decision by Apple to prevent users from using the pencil for anything other than artworking. We thought Apple had changed their mind about a Tablet being a failure if it works with a stylus. But they hadn't.
Very poor treatment of users. If Apple had wanted to make the pencil have no navigational functionality, they should have removed functionality from the start. To have that functionality and then take it away, is clearly contemptuous of its customers.
Trigati
209
This is exactly my stance on it. I really want the Pro and the Pencil was a no-brainer. Now, unless this is truly a bug and not a conscious decision to remove functionality, they've lost at least one Pencil sale. I'm no artist, but I do a lot of PDF work and the pencil would have been great. However, unless the current functionality in 9.2 is brought back into 9.3, I'll just buy a Jot Dash or something else I can use with all my devices for half the price.
Haalcyon
865
If I can't use the Pencil for navigation they can just keep it as I'm no artist either. I have a Jot Pro and I will just keep using it.
kvnchris99
Sep 29, 2013
9
Man, I REALLY hope they don't keep this idea implemented. I can understand how it might not look as "pure" in Jony's eyes using a Pencil to scroll safari, but omg it's SO convenient. And I'm talking when just laid back not even drawing or anything. Just that extra 8" reach being able to scroll or flip thru a book is seriously amazing. We should all submit feedback on this one. I won't upgrade if they change that!
Rene Ritchie
Old Man Ritchie
Jan 12, 2007
2,115
355
www.about.me
I'm still hoping it becomes a Settings switch, like the four finger gestures. I get why some people would prefer distinct multitouch versus pencil gestures. And they also get by someone that just your notification. Seems like one of those times when we really could have best of both worlds.
ianeb
83
The two are separate aren't they? Sure I've read it won't interfere with finger gestures, the iPad knows when the pencil is near and automatically starts scanning at a higher frame rate. Is a switch necessary? If you prefer to scroll and navigate with touch it should still function? Haven't actually got my pencil yet so apologies if I've read this wrong.
jsntrenkler
Trusted Member
Mar 9, 2010
2,779
55
Why would you need a switch? If you don't want to use the pencil keep it in your bag? Interesting part is that when you do have the pencil in hand it just feels more naturual to use it to select buttons and use as a virtual finger. That all changes when you set the pencil down and go back to using the iPad Pro without it.
reygza
Nov 14, 2015
41
New beta, and Pencil navigation is back for those crying for it.
I didn't care either way as I only used the Pencil when using a drawing/sketching app. Otherwise I left it in the bag.
FallDesigner
