1. waynjer64's Avatar
    Got a new iPad 12.9 and was getting to know it when I put the Safari into a split screen and now I don't even remember how I did it. However, I cannot get out of it with all my efforts at looking through settings and Safari help, nothing has worked.
    Has anyone had a similar problem with their ipad? If you have and have been able to go back and forth in the app, could you share with me how you do it? I am not talking about the smaller screen that you can pull from the right side out, but the complete split screen in Safari.
    Thanks a lot.
    Amazing...one can use Safari Help to solve problems. To enter split screen hold the box in box Left top corner and a drop menu will appear and from there select Open Split View. To exit split screen hold the same box in box and select Merge All Tabs. Solved my own question and maybe helped a few others.
    Cheers all.
    12-25-2016 04:52 PM
  2. Just_Me_D's Avatar
    To enable split view, simply swipe left from the right center edge of the display. To exit, slide the divider back to the right edge of the screen.
    12-25-2016 05:55 PM
  3. nthknd's Avatar
    Try this
    12-25-2016 06:08 PM
  4. nthknd's Avatar
    And split view/multitasking
    12-25-2016 06:18 PM
  5. nthknd's Avatar
    Not sure which one you are needing but this should help too
    12-25-2016 06:23 PM
Similar Threads
  1. Do you use a Tempered Glass screen protector on your iPad Pro 9.7?
    By felloffthetruck in forum iPad Pro (9.7-inch)
    Last Post: 04-21-2017, 08:49 PM
  2. Glass Screen Protector recommendations?
    By bparks115 in forum Apple Watch Series 2
    Last Post: 02-21-2017, 07:58 PM
  3. Screen freezes
    By 15obarclay in forum iPhone 6s
    Last Post: 01-15-2017, 08:44 AM
  4. Apple Watch screen cracked
    By alphatectz in forum Ask a Question
    Last Post: 12-24-2016, 04:45 PM
  5. Replies: 2
    Last Post: 12-23-2016, 08:11 PM
