1. JimMLINY's Avatar
    Way fast. Needs USB-C to Lightning cabling.
    08-06-2016 01:01 PM
  2. Just_Me_D's Avatar
    Okay. Submit feedback to Apple via the feedback option in it's website.
    08-06-2016 01:35 PM
  3. Beards's Avatar
    08-06-2016 01:35 PM
  4. TripleOne's Avatar
    Wished it came with the iPad Pro, instead of us having to spend more on the brick and the cable
    ladyc0524 likes this.
    08-06-2016 07:32 PM
  5. Honey Beagle's Avatar
    You can purchase that cable on eBay. Search item number 331925562353.
    08-06-2016 09:20 PM
  6. JimMLINY's Avatar
    I went Apple Store on this. No regrets.
    08-06-2016 10:05 PM
  7. Honey Beagle's Avatar
    That is also an option.
    08-06-2016 11:25 PM
  8. italodance's Avatar
    How much fast? the normal adapter takes 5 hours for charging 12.9 from 1 to 100% , what about this one? it means how many hours? Does it hurt your battery?
    08-07-2016 06:02 AM
  9. Rob Phillips's Avatar
    Best choice. That eBay cable isn't MFi certified from what I can see.
    08-07-2016 07:30 AM
  10. TripleOne's Avatar
    Considerably faster apparently..
    08-07-2016 07:56 AM
  11. jsntrenkler's Avatar
    Twice as fast from my experience totally worth the $70
    08-08-2016 12:58 AM
  12. JimMLINY's Avatar
    Two hour twenty minutes to go from 10% to 100%.
    italodance likes this.
    08-08-2016 01:39 AM
  13. TripleOne's Avatar
    Wow!
    08-08-2016 06:29 AM
  14. muchospanish's Avatar
    How much bigger and heavier is the cable?
    08-15-2016 10:34 AM
  15. TripleOne's Avatar
    I think it's the same size if I'm not mistaken.
    08-15-2016 04:34 PM
  16. JimMLINY's Avatar
    So timed it tonight by percent. 6:45 19%. 7:50 72%. 8:16 85%. 8:30 91%. 8:58 97%. 9:15 100%. The C set up is to right.
    Click image for larger version.
    muchospanish likes this.
    08-15-2016 08:42 PM
  17. italodance's Avatar
    I'm just about to order it but finally Does it hurt your battery health or not? could be harmful?
    08-24-2016 12:15 PM
  18. TripleOne's Avatar
    It shouldn't hurt your battery.
    08-24-2016 04:21 PM
Similar Threads
  1. Replies: 1
    Last Post: 08-07-2016, 01:31 PM
  2. Replies: 1
    Last Post: 08-06-2016, 05:05 PM
  3. Where is the mute button on my phone
    Last Post: 08-06-2016, 02:40 PM
  4. newly installed el capitan on 2010 Mac is slow. what to do?
    Last Post: 08-06-2016, 01:46 PM
  5. Why is my phone blocking certain websites?
    Last Post: 08-06-2016, 05:23 AM
