Does the iPad Pro drain a lot when charging the Pencil?
I
iMore Question
Is there a battery drain when plugging the Apple Pencil into their iPad Pro? How much power does it take to charge the Pen, how much battery from the iPad Pro is taken?
Garz
Retired Moderator
Mar 9, 2009
8,172
155
37
You can charge the pencil from dead to 100% with only about 1% of your iPad battery so there is nothing to be concerned about.
digitalbreak
Trusted Member
May 31, 2014
332
Depends on what you use the Pencil for.
With Procreate app, the iPad Pro battery drains significantly faster than say writing with OneNote.
smitty22d2
