How much is the Surface Pro 4 a threat to the iPad Pro
I'm interested to hear your thoughts on how these two fare against each other. There is probably such a thread here. If there is, get me the link.
Similarities are many between these two (styli, keyboard, even the names), so are the differences. The iPad carries a mobile OS unlike the Surface. Both have advantages. The Surface Pen is more robust. Apple designed a pencil without a rubber! Storage is bigger on the Surface (up to 1 TB). Then there full USB ports, better keyboard (touch pad). Apps thing seems equal (to me) since the iPad hundreds of thousand quality apps, while the SP4 has a great amount of desktop apps to work with.
The SP4 as a tablet has fewer apps. Windows 10 could change that, or at least make the gap smaller. And the OS is quite good too. As a workhorse it has an edge over the iPad due to its OS, on-board storage, better keyboard, can add more peripherals like mice, HDDs and USB drives, SD card slot?
As both are directed towards enterprise, should Apple have beefed up the iPad more? Like a OS X on touch display? None of them are yet to be delivered to customers , so numbers aren't there to look at.
