Will I be able to connect my iPad Pro to my SUV and use it as the LCD interface in the vehicle?
I
iMore Question
I have a Ford SUV that doesn't have an LCD interface. When I get my iPad Pro, would I be able to use it as the LCD interface?
Raptor007
Trusted Member
Jul 3, 2010
1,309
7
Re: Will I be able to connect my iPad Pro to my SUV and use it as the LCD interface in the vehicle
I doubt you would. I know Ford uses Sync, and unless it has a way to tie into the system over BT or a cable then unlikely. That said you may find support from aftermarket Audio/Video companies looking for ways to make the iPad Pro a second screen in the car via cable connection.
smitty22d2
