Welcome to the iMore Forums Create Your Account or Ask a Question Answers in 5 minutes - no registration required!
Results 1 to 22 of 22
  1. Thread AuthorThread Author   #1
    MisterMe11's Avatar
    iMore Newbie
    Posts
    Global Posts
    309 Global Posts
    Default bluetooth audio volume low
    Connecting to a Logitech Squeezebox boom through a Bluetooth adapter, and the volume is very low even at 100% on the iPad and 100% on the Squeezebox.
    Does anyone know a way to boost it? Other phones/tablets have higher volume. Thanks
    whiterob420 likes this.
  2. #2
    pkcable's Avatar
    Q&A Jedi
    Posts
    Global Posts
    39,588 Global Posts
    Default Re: bluetooth audio volume low
    Have you tried re pairing? Delete the profile from the ipad and from the device and then start over. Worth a shot.
  3. #3
    nnemeth's Avatar
    iMore Nanite
    Posts
    This is not a helpful hint. We all try to re-pair as this is the basic move. It is evident. The volume is still low. I assume the software should be improved that the users cannot help. Any better hint is very welcome as we cannot do anything with the recent software I guess.
  4. #4
    medic79's Avatar
    iMore Nanite
    Posts
    I've noticed that when I pair my beats wireless headphones that after about 5 min of listening they cut out and I need to delete the pairing and repair them. It's really annoying and only happens on the new ipad air, no issues with iPhone 4S, iPod touch, MacBook Pro. But when it does work the sound is great
  5. #5
    Rick Harris1's Avatar
    iMore Nanite
    Posts
    I have same/similar problem with iPad 3 and Vizio soundbar. The pairing went perfectly and the audio was great...later when I tried to play music again, the volume was incredibly low. Paired with Android tablet and all is well...it's something to do with the iPad.
  6. #6
    Xm_jdm's Avatar
    iMore Specialist
    Posts
    Global Posts
    5,088 Global Posts
    Quote Originally Posted by MisterMe11 View Post
    Can't say I have this problem on my JBL Pulse speaker. That's odd.
  7. #7
    WarrenLewis_3's Avatar
    iMore Nanite
    Posts
    I had the same problem with an aftermarket Bluetooth kit for my car. To get to the Bluetooth volume you have to connect to the Bluetooth device then make or receive a phone call. When you do it pops up a page where one of the options is Audio Source, in my case I had three choices (the Bluetooth car kit, the iphone, and the iphone speaker). I selected Bluetooth car kit and then pressed the '+' volume button on the side of the phone up to the max. It worked. I could never find any other place where you could set the Bluetooth volume.
  8. #8
    monewilliam's Avatar
    Banned
    Posts
    Global Posts
    5 Global Posts
    You are using a Bluetooth Music Receiver to connect with a Logitech Squeezebox boom. May I ask why, this an internet radio can be used to transmit signal through intranet. The quality is better through WiFi than Bluetooth.
  9. #9
    I wish I had a solution for you but I haven't experienced any issues connecting to my speaker or wireless headphones.
  10. #10
    b3boy's Avatar
    iMore Nanite
    Posts
    Yes, I found the way of using the side buttons to control bluetooth volume when phoning but on the next call it always defaults to the low setting again unlike 'Phone' and 'speaker' options which retain their settings until changed. If anyone knows how to turn this off or make a user default I'd love to here it. Meanwhile I've written a fairly detailed letter to Apple about this. I hope others do the same.
  11. #11
    John Joseph5's Avatar
    iMore Nanite
    Posts
    I just had this problem. Before trying to re-pair, go to settings and tell Bluetooth to forget the device, then re-pair.
  12. #12
    flagalpha's Avatar
    iMore Nanite
    Posts
    Thanks pkcable and johnJoseph5 ! )
    This nil volume issue drove me up the wall last night! grrr.
    I tried 'reconnecting' several times - that was no help.
    The trick is in telling your ipad to forget the device. ... (touch the little blue ringed "I" icon for this option)
  13. #13
    Vincent Mohanna's Avatar
    iMore Nanite
    Posts
    I just fixed the same issue I had with my iPhone 4S and an iHome Bluetooth wireless speaker.
    I went to settings and used "forget this device" on the iPhone. I then reconnected to the Bluetooth speaker and now the sound level is back to normal.
  14. #14
    motzart666's Avatar
    iMore Nanite
    Posts
    Quote Originally Posted by John Joseph5 View Post
  15. #15
    motzart666's Avatar
    iMore Nanite
    Posts
    I just toggled off and on the keyboard clicks switch under settings and the Bluetooth volume was normal again.
  16. #16
    motzart666's Avatar
    iMore Nanite
    Posts
    That is settings/sounds/keyboard clicks
  17. #17
    Chris Mcutchen's Avatar
    iMore Nanite
    Posts
    Thanks worked a treat
  18. #18
    maryekeis's Avatar
    iMore Nanite
    Posts
  19. #19
    maryekeis's Avatar
    iMore Nanite
    Posts
    Thanks. Worked immediately!
  20. #20
    laoudi's Avatar
    iMore Nanite
    Posts
    Hi everyone,
    I'm desperate. I tried eeeeeverything I found on several forums, including the advice provided by Apple, turn off Facebook, re-pairing, forget the bluetooth device and connect it again, change the volume via screen and buttons, change the sound settings on the Facebook app, change the audio settings of the iphone, etc. and I'm forgetting some.
    Would you have any other advice please ? The volume on my bluetooth speakers used to be way higher, I don't know why it changed. When I try to call someone while I'm connected to Bluetooth, the volume is really high, like it should be, but as soon as I change it back to music ... Low.
    I have an IPhone 5C.
    Thank you !!
  21. #21
    Diana Garcia4's Avatar
    iMore Nanite
    Posts
    Were you able to find a solution for this? We have a big blue party bluetooth speaker and anytime we connect via bluetooth the volume is very low.
  22. #22
    armedman's Avatar
    iMore Nanite
    Posts
    "laoudi"
    I have same problem ((
Similar Threads
  1. audio
    Last Post: 10-27-2013, 09:22 PM
  2. How do I adjust ringtone volume?
    Last Post: 10-25-2013, 09:29 PM
  3. Low Light Video Recording
    By JDabney in forum iPhone 5s
    Last Post: 10-25-2013, 02:42 PM
Posting Permissions
