All,
I figured out that Four Square was draining my battery on my iPhone 6. I started to notice my battery was draining faster than expected.
I went to look at the battery utilization feature and was only seeing the apps I was using at the top of the list.
I also was looking at the privacy feature and noticed that Four Square was always using the location feature (or just used it) when I looked. I decided to delete Four Square and noticed for 3 days after that my batteries performance improved significantly.
Has anyone had the issues?
Thanks,
A.B.
Thanks,
A.B.
