My phone is not ringing, only vibrating. Settings says it is on, volume is max. What could the problem be?
I
iMore Question
My phone is not ringing, only vibrating. Settings says it is on, volume is max,
Volume is loud when tested. Incoming call only vibrates
59,784
645
Re: My phone is not ringing, only vibrating. Settings says it is on, volume is max,
Go to Settings - Notifications - Phone, and then make sure that the toggle is enabled next to "Allow Notifications". After that, scroll down to "Sounds" and make sure that a ringtone is selected.
If that doesn't help, go to Settings - General - Reset, and then select "Reset All Settings".
Tomwex73
