does the remote control need to be in direct view of the Counsel in order to work
I
iMore Question
Can I mount the controller box behind my TV on the wall and still use the remote control or does the remote control need to be in direct view of the counsel in order to function
Tartarus
Feb 20, 2014
17,442
20
It depends on what console you're referring to but most modern consoles nowadays function on radio signals. If I were you I'd place the console out of sight first and try it out before mounting it.
