Welcome to the iMore Forums Create Your Account or Ask a Question Answers in 5 minutes - no registration required!
+ Reply
Results 1 to 2 of 2
  1. Thread AuthorThread Author   #1
    iMore Question
    iMore Question's Avatar
    Guest
    Default On my iPhone 6 the battery is discharging at a rapid rate. When I click on battery
    it shows that the Home and Lock Screen used up 83% during the past 24 hours. I've gone in circles following instructions for making sure the Home Button is not stuck and was able to find another home button and I got it to open and show six choices and the one on the bottom said HOME which I was told to press and I did. Then this little round shadowy circle appeared on the screen. I then back to settings and clicked on The CONTROL CENTER and the next window showed ACCESS ON LOCK SCREEN and ACCESS WITHIN APPS; Both were on (green). Shall I leave them on?
    MY PHONE WENT HAYWIRE AFTER UPDATING. THINK I'LL NEVER UPDATE AGAIN.
    Please help, I'll be grateful FOREVER
  2. #2
    nikkisharif's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Go to settings > general > background app refresh & turn off the apps you don't need running behind the scenes. You can also check notifications & location settings. No need to freak out & not take anymore updates. Sometimes updating resets those settings. You also probably want to change your screen brightness to auto. Good luck
Similar Threads
  1. Will an iphone make calls without a data plan
    Last Post: 10-12-2016, 07:44 PM
  2. How do I access my iCloud Keychain
    Last Post: 10-12-2016, 07:38 PM
  3. What setting allows you to turn off screen and leave on sound?
    Last Post: 10-12-2016, 06:01 PM
  4. Where's the Samsung shaped dent in the universe?
    By iMore.com in forum iMore.com News Discussion
    Last Post: 10-12-2016, 06:00 PM
  5. Why I cannot delete an app on my phone?
    Last Post: 10-12-2016, 05:49 PM
Posting Permissions
