1. iMore Question's Avatar
    ive taken it to apple twice but problem persists
    whats the fix for this ?
    01-25-2015 02:24 PM
  2. Reparkable's Avatar
    Keep taking it back to Apple
    01-25-2015 04:06 PM
  3. Ledsteplin's Avatar
    Maybe it's what you're doing on the phone. To see if the battery is bad, take this test:
    Write down your usage and standby time, press the sleep/wake button (or lock button, as some call it) to put the device to sleep, and set the device down for five minutes. When you come back, take note of the change in time. If your device is sleeping properly, then the Standby time should have increased by five minutes and your Usage time by <1 minute . If your Usage time rises by more than one minute, you have a drain problem. Something is keeping your device from sleeping properly, significantly shortening the time it will last.
    Sent from my ancient but trustworthy iPhone 5.
    01-25-2015 04:47 PM
  4. pr1nce's Avatar
    Maybe it is how you're using it. Battery life on my 5s is good. Good luck.
    01-25-2015 05:28 PM
  5. Stephmac69's Avatar
    hi thanks for replying my iphone drains overnight when on stand bye ive taken it to genius bar they done a D F U
    and they said iy would fix problem but it still does it.
    ive tried all the battery saving tips but it still drains
    and my phone is out of warranity what can i do to first diagonose whats wrong with it ?
    and howe to fix?
    01-26-2015 11:12 AM
  6. WadeHM's Avatar
    Your new battery may be defective. Where did you get it and who installed it? If its a recently purchased battery you should have a warranty on it.
    Sent via
    01-27-2015 02:21 PM
Similar Threads
  1. Why won't the GPS work on my iPhone 5c iOS 8.1.2?
    Last Post: 01-25-2015, 02:20 PM
  2. Replies: 1
    Last Post: 01-25-2015, 02:17 PM
  3. How do I back up to iCloud on my iPhone 5?
    Last Post: 01-25-2015, 01:41 PM
  4. Replies: 0
    Last Post: 01-25-2015, 01:00 PM
  5. Last chance to back Lucidream eXo-Skelton case for iPhone!
    By iMore.com in forum iMore.com News Discussion
    Last Post: 01-25-2015, 10:12 AM
