My battery is draining fast after using unauthorized charger, is that normal?
I
iMore Question
my battery is draining fast after using unauthorized charger
What can be the problem if my battery is draining far after using unauthorized charger? I have tried to change battery which didn't help at all.
The iPhone is able to charge but after hour and a half the battery is dead.
thanks!
kch50428
21,025
305
Re: my battery is draining fast after using unauthorized charger
likely the unauthorized charger has caused an issue with the port... those can be replaced by qualified service personnel...
