Why does the sound keep going out on my iPhone 5?
I
iMore Question
why does the sound keep going out on my iphone 5
It is random whether I hear a sound when I receive a text or mail notification. If I turn my phone off and then on again, it will work for about 20 minutes or so and then again, I have no sound and I cannot hear when somebody texts me or if I receive mail.
qbnkelt
5,213
6
33
Re: why does the sound keep going out on my iphone 5
You said you turn your phone off and on again, do you mean a reset or just turning it off and on? There is a difference.
If you haven't done a reset by holding the home and power button at the same time and letting go after the Apple logo appears, you might want to try that.
If you have done that and you have a good backup from before this issue started I would reset then restore from backup.
Sent from my SEXY GORGEOUS AWESOME GOLD 128G iPhone 6
Tomwex73
