1. 9439's Avatar
    I've read that when you remove an AirPod the audio pauses then resumes when reinserted. The pause works fine but will not resume. Anyone else ?
    UPDATE: Never mind ,resume play works when using both. Really liking them so far.
    The right AirPod infrared sensor seems to struggle more than the left one, anyone else? Still loving them.
    12-26-2016 12:26 AM
  2. Tartarus's Avatar
    Nope, no issues so far.
    I've been using them for over a week now and have not found a single thing that doesn't work well.
    12-26-2016 03:06 PM
  3. olearydan's Avatar
    I actually have major connection problems with my AirPods. It's been happening since day one and I've been trying to trace down the problem. This website describes my problem basically exactly as I'm running a 6S with a paired Apple Watch. I unpaired my watch today and ran with no issues for over an hour, but as soon as I paired my watch again the audio and pairing issues returned. I need my Apple Watch paired more than I need my AirPods to work, but it's still unfortunate. The AirPods work flawlessly when I'm using them with my MacBook Air as well as my iPad. The issue seems to reside in the phone somewhere.
    01-19-2017 10:08 PM
  4. Twenty7delta's Avatar
    I find I have to wiggle the left one around in my ear to get it to turn on. I figure I'll find the trick eventually
    01-19-2017 11:46 PM
  5. lowlifeplayer's Avatar
    The problem seems to have been addressed in version 3.3. I noticed that my AirPods connect a lot faster and the pop up with battery information appears in a more consistent manner.
    02-02-2017 07:53 AM
  6. radklin's Avatar
    Not sure where this should go so I will just ask here. I have my airpods connected to my iphone with no problem. But on my apple watch series one I can not get the battery indicator to work. I know how to do it I hit the control panel and tap the battery icon, but it just shows me the watch battery whats wrong?
    02-10-2017 02:10 PM
  7. Just_Me_D's Avatar
    Make the battery a complication and then select it. You should see something similar to that in the screenshot.
    radklin likes this.
    02-10-2017 02:16 PM
  8. radklin's Avatar
    I must be getting old. I restarted the watch and then it showed me. Thanks for the tip anyways.
    02-10-2017 02:54 PM
  9. Just_Me_D's Avatar
    You're very welcome...
    Twenty7delta likes this.
    02-10-2017 04:17 PM
Similar Threads
  1. Ordered Verizon AirPods - not available
    By Owen Hayes1 in forum AirPods
    Last Post: 01-12-2017, 07:40 AM
  2. Replies: 2
    Last Post: 12-26-2016, 06:40 AM
  3. Split screen problem
    By waynjer64 in forum iPad Pro (12.9-inch)
    Last Post: 12-25-2016, 06:23 PM
  4. Replies: 0
    Last Post: 12-25-2016, 10:20 AM
  5. How would you change AirPods?
    By iMore.com in forum iMore.com News Discussion
    Last Post: 12-24-2016, 01:49 PM
